Mar 13, 2017 2:04 PM UTC
Create service programmatically
I would like to build a form which will allow users to create services without entering the composer.
So is it possible to create services programmatically without using remote services ?
Regards
Mar 16, 2017 11:25 PM UTC
// For this example, we'll have an Math service
// which takes two numbers, and an operation.
// The result will be that operation performed on the two inputs.
// We either need an Application Key,
// or user credentials to perform the reads and writes.
// App keys are a little safer.
// In this demo, we'll store it on the Entity as a Property.
var appKey = me.appKey;
// The service name needs to be unique and not already in use.
var serviceName = "MyMath";
// What are the inputs to the service?
// We'll define them nicely here, but manipulate this object later.
var parameters = {
    "op" : "STRING",
    "x" : "NUMBER",
    "y" : "NUMBER"
// What datatype does the service return?
// If it's an infotable,
// then you'll also have to specify the data shape
// as part of the resultType's aspect,
// but I won't demonstrate that here.
var output = "NUMBER";
// What is the actual service script?
// We'll define it here as an array of lines, and then join them together.
var serviceScript = [
    "var result = (function() {",
    "  switch(op) {",
    "    case \"add\": return x + y;",
    "    case \"sub\": return x - y;",
    "    case \"mult\": return x * y;",
    "    case \"div\": return x / y;",
    "    default: return op in Math ? Math[op](x, y) : 0;",
].join("\n");
// Let's convert the friendly parameter definition
// into the structure that ThingWorx uses:
var parameterDefinitions = Object.keys(parameters).reduce(function(parameterDefinitions, parameterName, index) {
    var parameterType = parameters[parameterName];
    parameterDefinitions[parameterName] = {
        "name": parameterName,
        "aspects": {},
        "description": "",
        "baseType": parameterType,
        "ordinal": index
    return parameterDefinitions;
//  Now let's set up our service definition and implementation.
var definition = {
    "isAllowOverride": false,
    "isOpen": false,
    "sourceType": "Unknown",
    "parameterDefinitions": parameterDefinitions,
    "name": serviceName,
    "aspects": {
        "isAsync": false
    "isLocalOnly": false,
    "description": "",
    "isPrivate": false,
    "sourceName": "",
    "category": "",
    "resultType": {
        "name": "result",
        "aspects": {},
        "description": "",
        "baseType": output,
        "ordinal": 0
var implementation = {
    "description": "",
    "handlerName": "Script",
    "configurationTables": {
        "Script": {
            "isMultiRow": false,
            "name": "Script",
            "description": "Script",
            "rows": [{
                "code": serviceScript
            "ordinal": 0,
            "dataShape": {
                "fieldDefinitions": {
                    "code": {
                        "name": "code",
                        "aspects": {},
                        "description": "code",
                        "baseType": "STRING",
                        "ordinal": 0
// Here are the URLs we'll need in order to make updates.
// You can change the thing name ('ServiceModifier' here)
// to something else.
// If you use credentials instead of an app key,
// then you can remove the appKey parameter here,
// but you'll have to add the username and password
// to the two ContentLoaderFunctions calls.
var url = {
    export : "http://127.0.0.1:8080/Thingworx/Things/ServiceModifier?Accept=application/json&appKey="+appKey,
    import : "http://127.0.0.1:8080/Thingworx/Things/ServiceModifier?appKey="+appKey
// We can download the entity to modify as a JSON object.
// Older versions of ThingWorx might not support this.
var config = Resources.ContentLoaderFunctions.GetJSON({
    url : url.export,
// We have to modify both the 'effectiveShape',
// as well as the 'thingShape'.
config.effectiveShape.serviceDefinitions[serviceName] = definition;
config.effectiveShape.serviceImplementations[serviceName] = implementation;
config.thingShape.serviceDefinitions[serviceName] = definition;
config.thingShape.serviceImplementations[serviceName] = implementation;
// Finally, we can push our updates back into ThingWorx.
Resources.ContentLoaderFunctions.PutText({
    url : url.export,
    content : JSON.stringify(config),
    contentType : "application/json",
// The end.
22-Sapphire I
Mar 13, 2017 2:09 PM UTC
there is another thread talking about this
Modify service code programmatically
jdurand1-VisitorAuthor
Mar 13, 2017 2:14 PM UTC
Ok so it is not 😕
var parameters = {
    "op" : "STRING",
    "x" : "NUMBER",
    "y" : "NUMBER"
    "  switch(op) {",
].join("\n");
        "aspects": {},
        "description": "",
        "ordinal": index
var definition = {
    "isOpen": false,
    "aspects": {
        "isAsync": false
    "description": "",
    "isPrivate": false,
    "sourceName": "",
    "category": "",
    "resultType": {
        "name": "result",
        "aspects": {},
        "description": "",
        "baseType": output,
        "ordinal": 0
    "description": "",
        "Script": {
            "name": "Script",
            "rows": [{
            "ordinal": 0,
            "dataShape": {
                    "code": {
                        "name": "code",
                        "aspects": {},
                        "ordinal": 0
var url = {
    url : url.export,
    url : url.export,
// The end.
