Apr 13, 2017 8:05 AM UTC
Create a service dynamically
Disclaimer: example was provided by Hatcher Chad - chad@onfarmsystems.com
  // For this example, we'll have an Math service
  // which takes two numbers, and an operation.
  // The result will be that operation performed on the two inputs.
  // We either need an Application Key,
  // or user credentials to perform the reads and writes.
  // App keys are a little safer.
  // In this demo, we'll store it on the Entity as a Property.
  var appKey = me.appKey;
  // The service name needs to be unique and not already in use.
  var serviceName = "MyMath";
  // What are the inputs to the service?
  // We'll define them nicely here, but manipulate this object later.
  var parameters = {
  "op" : "STRING",
  "x" : "NUMBER",
  "y" : "NUMBER"
  // What datatype does the service return?
  // If it's an infotable,
  // then you'll also have to specify the data shape
  // as part of the resultType's aspect,
  // but I won't demonstrate that here.
  var output = "NUMBER";
  // What is the actual service script?
  // We'll define it here as an array of lines, and then join them together.
  var serviceScript = [
  "var result = (function() {",
  " switch(op) {",
  " case \"add\": return x + y;",
  " case \"sub\": return x - y;",
  " case \"mult\": return x * y;",
  " case \"div\": return x / y;",
  " default: return op in Math ? Math[op](x, y) : 0;",
  ].join("\n");
  // Let's convert the friendly parameter definition
  // into the structure that ThingWorx uses:
  var parameterDefinitions = Object.keys(parameters).reduce(function(parameterDefinitions, parameterName, index) {
  var parameterType = parameters[parameterName];
  parameterDefinitions[parameterName] = {
  "name": parameterName,
  "aspects": {},
  "description": "",
  "baseType": parameterType,
  "ordinal": index
  return parameterDefinitions;
  // Now let's set up our service definition and implementation.
  var definition = {
  "isAllowOverride": false,
  "isOpen": false,
  "sourceType": "Unknown",
  "parameterDefinitions": parameterDefinitions,
  "name": serviceName,
  "aspects": {
  "isAsync": false
  "isLocalOnly": false,
  "description": "",
  "isPrivate": false,
  "sourceName": "",
  "category": "",
  "resultType": {
  "name": "result",
  "aspects": {},
  "description": "",
  "baseType": output,
  "ordinal": 0
  var implementation = {
  "description": "",
  "handlerName": "Script",
  "configurationTables": {
  "Script": {
  "isMultiRow": false,
  "name": "Script",
  "description": "Script",
  "rows": [{
  "code": serviceScript
  "ordinal": 0,
  "dataShape": {
  "fieldDefinitions": {
  "code": {
  "name": "code",
  "aspects": {},
  "description": "code",
  "baseType": "STRING",
  "ordinal": 0
  // Here are the URLs we'll need in order to make updates.
  // You can change the thing name ('ServiceModifier' here)
  // to something else.
  // If you use credentials instead of an app key,
  // then you can remove the appKey parameter here,
  // but you'll have to add the username and password
  // to the two ContentLoaderFunctions calls.
  var url = {
  export : "http://127.0.0.1:8080/Thingworx/Things/ServiceModifier?Accept=application/json&appKey="+appKey,
  import : "http://127.0.0.1:8080/Thingworx/Things/ServiceModifier?appKey="+appKey
  // We can download the entity to modify as a JSON object.
  // Older versions of ThingWorx might not support this.
  var config = Resources.ContentLoaderFunctions.GetJSON({
  url : url.export,
  // We have to modify both the 'effectiveShape',
  // as well as the 'thingShape'.
  config.effectiveShape.serviceDefinitions[serviceName] = definition;
  config.effectiveShape.serviceImplementations[serviceName] = implementation;
  config.thingShape.serviceDefinitions[serviceName] = definition;
  config.thingShape.serviceImplementations[serviceName] = implementation;
  // Finally, we can push our updates back into ThingWorx.
  Resources.ContentLoaderFunctions.PutText({
  url : url.export,
  content : JSON.stringify(config),
  contentType : "application/json",
  // The end.
7-Bedrock
Jun 1, 2017 1:48 PM UTC
Thanks Vladimir, I'll refer to this from my other thread: Modify service code programmatically
/ Constantine
