how can i generate database report in thingworx?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hi ,
I am looking to generate database report(multiple database). can you explain here in few lines?
- Labels:
Best Practices
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @VaibhavShinde.
Please refer to this page from our ThingWorx Help Center and follow the examples provided.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Could you please elaborate on the use case here and your requirements?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I want to generate report in Grid format by retrieving data from database table , and i need to filter by using one of the column name with export button which will export data to excel.
How we can create it?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Is your database already connected to ThingWorx? You can connect any relational database via jdbc driver.
You would then write a sql command/query in a service to retrieve data. In the mashup, you can then use the advanced grid, a filter widget, and your query service bound to the filter and the grid to filter and sort data.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
yes I have connected the Database but I am unable to filter the data in Adv grid using data filter widget, I have nothing in service , just retrieving data and Infotable as output. I am sharing screenshot plz see it .hope u would reply with best solution.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Could you help me please. I have shared you the screenshots.
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
You would need to enable sorting on the grid as well as a couple of other things for binding, mentioned in this article:
https://www.ptc.com/en/support/article?n=CS282617
I'm also attaching sample entities for the advanced grid. Please run the InitTable services on the Thing first to prepopulate the tables.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @VaibhavShinde.
If the response provided by @posipova answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi Slangley,
i have done half of the part that is i retrieved data in grid but i am unable to filter it with advanced filter widget.
could you please help me out, i have simple one line code in service that is sql query for data retrieval and i am binding it to grid in mashup section but how to bind it to Filter widget ? , even i can see my columns in filter widget but after filtering grid is not refreshing,
Thank you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @VaibhavShinde.
--Sharon
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @VaibhavShinde.
Please let us know if you have resolved your issue. If so, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
