I have created a mashup and used it in collection and am not able to change the stroke color using Custom CSS kindly some one advice what i need to do, do give the shapes different color based on their name.
Have you tried using state based definitions?
The widget should have certain properties that I think are called 'formatter' to allow for a state based definition to be associated.
Yeah, in that shape already data is binded from a different property so i cannot map the Machine name function to it.
You could always create a wrapper service to combine the necessary information you need.
