I have downloaded the licence file for Thingworx 8.5. I have put it in Thingworx Platform folder and rename it to licence_capablity_response_bin but after restarting the tomcat server. The name got changed to ignored_license_capablity_response.bin file. Do i have to generate new license file and place it in Thingworx folder or I don't have to make any changes.
I can see your license is active and all the features are available.
You should be able to use Thingworx at full capability( create things, mashups ....).
Raluca Edu
licence_capablity_response_bin is not correct name.
It should be license_capability_response.bin.
Rename file like this and restart server, you do not need to download another license.
Best regards,
Raluca Edu
I have renamed it to license_capability_response.bin but after restarting the tomcat server, it got changed to ignored_license_capability_response.bin.
in the logs
i see this error
Unable to fetch license file with device id 5058cf58-86a4-40fa-b8ea-778745ae4566
did you downloaded the license file using device id only ? 5058cf58-86a4-40fa-b8ea-778745ae4566 or that was different
which you renamed as license_capability_response.bin"
I have downloaded the file using device id only.
I can see you are using HA - Zookepeer and I can see Licensing Subsystem started.
Can you open Composer? If yes go to Licensing Subsystem>Services and run GetCurrentLicenseInfo service.
What is the result?
Raluca Edu
Raluca Edu
Okay, Thank You
