increasing the memory in apache 9.0
sanjanabalaji
11-Garnet
I am using Thingworx version 8.5. How to increase the memory size in apache 9.0?
Please follow solution from here: https://www.ptc.com/en/support/article/CS306401
Hope it helps,
Raluca Edu
Hope it helps,
Raluca Edu
Hi @sanjanabalaji.
If you have addressed your issue with the solution provided, please mark Raluca's response as the Accepted Solution for the benefit of others with the same question.
--Sharon
