linking one mashup with another mashup?
smamidigumpula
Hello Friends,
How can I link multiple mashups in one mashup such that if any one click on at some latitude and longitudinal on google map of a mashup it should navigate to another mashup. How can I implement it? Please help me.
sasivardhan
  • You can create a service which returns an InfoTable with at least two fields Locations and MashupName
  • Then bind the InfoTable to the map and display the locations on the map
  • Bind the service above / SelectedRow / MashupName to a Navigation widget / MashupName
  • Bind the map Double-click event to the Navigation widget
Now double-click on one location will open the mashup associated.
Hope this helps.
Quang-Dung
Hi sasivardhan mamidigumpula​,
Please check the following article, it is regarding the same scenario.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS249997&lang=en_US
I hope it helps.
Ankit Gupta
