yesterday, I installed local version of 90 days. but now I am not able to login localhost:8080/Thingworx/
I am sure about password and using "Administrator" as user.
please help me out, Thank you.
Check if Tomcat is actually up and running, you can check in Services
you can then check localhost:8080 or localhost to see if it comes up
also double check you are not going to https://localhost but http://localhost
