Jul 7, 2021 2:12 PM UTC
not able to login localhost
yesterday, I installed local version of 90 days. but now I am not able to login at localhost:8080/Thingworx/
I am sure about password. And I am using "Administrator" as user.
please help me out, Thank you.
Jul 8, 2021 4:04 PM UTC
Thank you so much for your help,
I have solved the issue. I came to know that I had imported "User" in localhost which was exported from my Cloud composer. So, I reinstalled localhost and then imported every entity again (except User.xml)
Jul 7, 2021 2:17 PM UTC
You are seeing the login pop up but once you enter username -Administrator and password it does not open the composer? In that case, I believe the issue is with your password. If feasible can you attach security logs from ThingWorxStorage->logs directory?
Jul 7, 2021 2:46 PM UTC
Yesterday I was able to login with same password and I have saved password in chrome. I have attached today's and yesterday's security logs.
milan.pansuriya1-VisitorAuthorAnswer
