problem with "QueryPropertyHistory""
AkshayKumar
Hi ,
I have done with Raspberry pi Quick start guide using EMS, now i want to Store those readings in Value stream, if i create a value stream and assign to the Thing,,
Generic services "QueryPropertyHistory" showing nothing Values instead just showing "Timestamp".
I also tried with Creating datashape,but no result..is it Possible to store values in "ValueStream" without creating "ThingTemplate",,,if so How???
Thank you!!
jdass
(To:AkshayKumar)
Hi Akshayakumar,
Did you check on logged for the property that you want to be logged in Value Stream?
jdass
(To:AkshayKumar)
Hi Akshayakumar,
Thank you soo much sir,
That was the issue.
now working properly
