How can I localize Thing properties?
shasegawa
When I display Thing properties using Value Display or Label widget, how can I localize value? It seems that Value Display widget does not accept localize token. Label widget accepts Localize Token, However, when it is bound to property of Thing,  the property do not seem to be treated as Localization token.
posipova
20-Turquoise
(To:shasegawa)
Currently it's not supported, however, there is a Jira for this.
Please see the following article for a possible workaround https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS252326&lang=en_US
posipova
20-Turquoise
(To:shasegawa)
Thank you for the helpful information.
Have a look at my updated Value Display widget post, Localised (or Localized) Value Display Widget
HTH
Wayne
