"State definitions" for values, not only styles
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Have service where I receive infotable, and show it in grid.
One of column is STATUS, with integer values to present OK/NOK, maybe different in future.
Style for whole row is set acc. STATUS column, so if there is 2 (which means NOK), whole row is described in red.
Is there also a way (configurable via mashup, style definitions, etc.), to display NOK instead of 2, OK instead of 1, etc.?
Or the only way is to change it inside service?
- Labels:
Design
Mashup-Widget
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @ZbigniewK ,
As far as I'm concerned, state definitions can only change the style, not the value, if you want to change/replace the actual value to be displayed in grid, you will need to incorporate that logic in your data service and return processed data and populate it to grid.
Best,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
State formatting applicable at cell level not row level. May be you can apply same state format (background red/green) for all columns.
Try to follow the below articles,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hello @ZbigniewK,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @ZbigniewK ,
Best,
