Jul 29, 2024 9:45 AM UTC
"State definitions" for values, not only styles
Have service where I receive infotable, and show it in grid.
One of column is STATUS, with integer values to present OK/NOK, maybe different in future.
Style for whole row is set acc. STATUS column, so if there is 2 (which means NOK), whole row is described in red.
Is there also a way (configurable via mashup, style definitions, etc.), to display NOK instead of 2, OK instead of 1, etc.?
Or the only way is to change it inside service?
TonyZhangAnswer
Support
Dec 10, 2024 7:02 AM UTC
Hi @ZbigniewK ,
As far as I'm concerned, state definitions can only change the style, not the value, if you want to change/replace the actual value to be displayed in grid, you will need to incorporate that logic in your data service and return processed data and populate it to grid.
Best,
Jul 29, 2024 10:11 AM UTC
State formatting applicable at cell level not row level. May be you can apply same state format (background red/green)  for all columns.
Try to follow the below articles,
Emeritus
Aug 2, 2024 9:06 AM UTC
Hello @ZbigniewK,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
TonyZhangCommunity ManagerAnswer
Support
Hi @ZbigniewK ,
Best,
