Have service where I receive infotable, and show it in grid.
One of column is STATUS, with integer values to present OK/NOK, maybe different in future.
Style for whole row is set acc. STATUS column, so if there is 2 (which means NOK), whole row is described in red.
Is there also a way (configurable via mashup, style definitions, etc.), to display NOK instead of 2, OK instead of 1, etc.?
Or the only way is to change it inside service?
State formatting applicable at cell level not row level. May be you can apply same state format (background red/green) for all columns.
Try to follow the below articles,
Hello @ZbigniewK,
It looks like you have a response from a community member. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
