sending GPS Tracker data to thingworx
Peter_Raj
11-Garnet
Dear All
Am currently working on LIve monitoring of GPS TRACKER in thingworx
i have a GPS tracker i want the display the real time data and the historical data to Thingworx
I had tried to fetch GPS Data from the Webpage to Excel but it is not coming
so can anyone guide to how to fetch the data from my GPS TRACKER from the website to kepserverEx and there by display in Thingworx
Thanks and regards
Peter Raj D
1 ACCEPTED SOLUTION
I did not work too much with Kepserver, but I will describe some general steps that I would do to start.
First need to find out what connectivity capabilities has the GPS tracker, only in its specification you can find this.
Please see this article: https://www.ptc.com/en/support/article?n=CS313370
If you find a driver that can connect GPS Tracker and Kepware, then you need to send data to Thingworx after installing KepServer Extension
Steps to connect Kepserver and Thingworx are described here.
For different kind of setup, configuration regarding Kepserver and Kepserver Extension I encourage you to search articles in PTC Knowledge Base available at support.ptc.com
Hope it helps,
Raluca Edu
2 REPLIES 2
Hope it helps,
Raluca Edu
slangley
23-Emerald II
(To:Peter_Raj)
Hi @Peter_Raj.
If the response provided by @raluca_edu answered your question, please mark it as the Accepted solution for the benefit of others with the same question.
--Sharon
