setting up second persistence provider
Sruthi
can i add second persistence provider different from first persistence provider?
ex. first persistence provider: postgresql
second persistence provider: MSSQL
Is a combination like this possible ?
8 REPLIES 8
raluca_edu
(To:Sruthi)
As far as I know it is not possible, second persistence provider can be Influx DB.
So you can have:
- first persistence provider: PostgresSQL or MSSQL
- Second persistence provider: Influx DB
If you want to connect to another database (not as persistence provider), you can use an extension https://marketplace.ptc.com/apps/195356/jdbc-connector-extension#!overview
Hope it helps,
Raluca Edu
Sruthi
(To:raluca_edu)
So the second persistence provider should be same as the first right? In case if we want it to be different we can go for Influx db right?
raluca_edu
(To:Sruthi)
From my point of view, second persistence provider should be Influx, so is not the same as the first one.
What you want to achieve?
Raluca Edu
Sruthi
(To:raluca_edu)
my doubt is..If I want to setup a second persistence provider, should it be the same as first or we can setup a different one?
raluca_edu
(To:Sruthi)
I cannot see any reason/use case to set a second persistence provider same as the first one. So, from my point of view, second persistence provider should be different than the first.
Hope it helps,
Raluca Edu
Sruthi
(To:raluca_edu)
ok. Thanks for your reply
slangley
23-Emerald II
(To:Sruthi)
Hi @Sruthi.
Here is a link to the ThingWorx Help Center with more information on persistence providers.  Hopefully, this information will help to answer your questions.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @Sruthi.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution for the benefit of others with the same question.
--Sharon
