shall we disable this column selection popup which comes while right clicking the adv-grid columns.
This property is working fine in grid properties when configuration json is not used.
But in my scenario, configuration json is used. And "enablacontextmenu" property i not available after configuration binding. Now how to disable column menu when configuration json is passed?
Yes this worked. Thanks
