I was trying to import the data of Value Stream from Postgres to InfluxDB. When I checked the Application Logs, I saw the following Info:
Getting License Feature Info for: twx_telemetry_data_exception
What does this mean? Am I missing something?
We use the Model DB as Postgres and InfluxDB as Time Series Data per the solution.
I think this license feature is related to the newly introduced data collection feature in ThingWorx
https://www.ptc.com/en/support/article/cs377271
See Enhancements > Platform the first one in below Help Center about this new feature
@pshashipreetham please describe first how you import data to InfluxDB.
Do you have 2 tw instances, one with PostgreSQL and the other with InfluxDB, and you are exporiting data from instance with PostgreSQL then import to instance with InfluxDB? Correct me if I am wrong.
