I've discovered what seems to be an iOS-specific bug. Here's the scenario:
I have a 3DImage (a warning icon) that needs to flash in the experience. I accomplish this using a $timeout that toggles the "visible" property on the widget, something like this:
$scope.blinkStatus = true;
$scope.blink = function() {
$scope.blinkStatus = !$scope.blinkStatus;
$scope.setWidgetProp("3DImage-1","visible", $scope.blinkStatus);
$timeout($scope.blink, 500);
This works just as it should on the preview and on Android. But on iOS, if you let the blinking continue for any length of time (about a minute or so), it crashes Vuforia View completely.
It only seems to happen with 3DImage widgets. I'm able to flash a normal 2D image widget in the same way without the app crashing.
Is this a known issue? I'm going to investigate workarounds, maybe using opacity. In the meantime, I'll attach a simple project file that demonstrates the problem.
Hello Clay,
I have checked the example Project.
I am able to have the crash in Android Vuforia View also as in in Ipad!
In Vuforia View log files, I didn't an error related to this crash.
I am reporting that to R&D as a bug.
More details in this article :
https://www.ptc.com/en/support/article?n=CS314554
Best regards,
Samuel
Also, FWIW, this also seems to happen if I use $interval instead of $timeout
It seems to work to use "opacity" instead of "visible" to control flashing, i.e. I can cycle opacity between 0 and 1 to achieve a flashing effect without causing the app to crash.
Hello Clay,
Best regards,
Samuel
Hi @ClayHelberg ,
I want only to suggest an additional option to this how to create some flash effects with javaScript in studio.
Calling some function recursively lead often to smart and elegant solutions but this is the case when we have a known, finite number of iterations. I think recursive calling with infinte number of recursions could lead to problems like crash or loss of performance. Therefore I will prefer a solution based on interval or other programming loop.
Here is an example of such solution (post )
So, for example I could get the same effect in your project if I use the code:
///// workaround with interval
$scope.blinkWork1 = function (){
console.log('blink 1')
var i;
var timingInterval = 300;
var numberOfBlinks=1000
i = 0;
for (i = 0; i < numberOfBlinks; i++){
$scope.setColormItem( timingInterval*i)
$scope.unsetColormItem(timingInterval*i +timingInterval/3)
$scope.setColormItem(timingInterval*i +timingInterval*2/3)
$scope.setColormItem= function(info)
$timeout(()=>{
console.log( "info="+info)
$scope.setWidgetProp("3DImage-1","visible", true);
},info)
$scope.unsetColormItem= function(info)
$timeout(()=>{
$scope.setWidgetProp("3DImage-1","visible", false);
},info)
Possible is also the usage of some shaders to change the display of the Image 3d element :
Here I changed the apperance to shaded (using a pinger shader) and back to non shaded picuture with a code like:
//// the same as above but using shader
$scope.blinkWork2 = function (){
console.log('blink 2')
var i;
var timingInterval = 3000;
i = 0;
$scope.setColormItem1("1.0","0.5","0.75", timingInterval*i)
$scope.setColormItem1("0.8","0.3","0.5",timingInterval*i +timingInterval/3)
$scope.unsetColormItem1(timingInterval*i +timingInterval*2/3)
$scope.setColormItem1= function(r,g,b,info)
$timeout(()=>{
console.log( "info2="+info)
$scope.setWidgetProp("3DImage-1","shader", "pinger; rings f 6;rate f 2;r f 0.0;g f 1.0;b f 0.0;direction f 1;fade f 0.0");
$scope.setWidgetProp("3DImage-1","src", "app/resources/Uploaded/pinger_tap.png?edge=repeat");
},info)
$scope.unsetColormItem1= function(info)
$timeout(()=>{
$scope.setWidgetProp("3DImage-1","shader", "");
$scope.setWidgetProp("3DImage-1","src", "app/resources/Default/thing_code.png");
},info)
Thanks for taking the time to look into it, @RolandRaytchev . I always learn something from your detailed posts. I have a few questions about your approach here:
Hi @ClayHelberg ,
first I want to say thank you, for the great and very detailed list of the reasons and technical points of the application side.
I fully agree with you!
Please, let, consider my post only as additional information and way without saying that it is better as your solution.
I agree also that this is a bug which should be fixed to the Jira ticket reported by @sdidier
Many thanks for the helpful information!
