Change size of widget Javascript
Giuseppe_Fiore
 I wanted to know if there was a way to change the Height or Width of a 3d widget (eg Image3D) BY JAVASCRIPT.
I TRIED TO USE THE SYNTAX :
$ scope.size = function () {
$ scope.view.wdg ['3DImage-1']. height = 2;
 BUT NOT WORKING:
thnx
Giuseppe
Hi Giuseppe,
Width and height are not currently dynamic properties. They cannot be changed after the image has been added to the scene. The closest equivalent you can use for this is 'scale' property.
1 REPLY 1
Hi Giuseppe,
