Community login and other support tools will be unavailable Saturday May 3rd 9:00 am to 3:00 pm (EST) due to planned maintenance. Learn More
Create a video for IOS
fguerra
I uploaded a video to be played in my experience, when I test it in an Android device it works fine but when an iPad or iPhone is used the video play in full screen.
Is it anyway to avoid this to play the video at the size I create it?
Thanks and best regards
Felix
12 REPLIES 12
dupatel
(To:fguerra)
Felix Guerra​: Could you please confirm the video file format been used . Is it an .mov file ?
-Durgesh
fguerra
(To:dupatel)
Hello Durgesh,
I'm using *.mp4
- Felix
fguerra
(To:fguerra)
Hi Durgesh Patel​,
Any news on this issue?
-Felix
dupatel
(To:fguerra)
Felix Guerra​,
Could you please confirm and verify that you are using the supported iOS as shown below:
-Durgesh
fguerra
(To:dupatel)
Hello Durgesh Patel​,
I'm using and Iphone 6 with iOS v10.3.1 and and Ipad Air 2 iOS v10.2.1 same results in both devices but not in Android based phone.
Felix
dupatel
(To:fguerra)
Felix Guerra​: Thanks for confirming on the version and I believe this is a defect with iOS. I will raise this with R&D team and will update you with their feedback.
-Durgesh
fguerra
(To:dupatel)
Hi Durgesh Patel,
Any news from R&D on this problem?
dupatel
(To:fguerra)
Felix Guerra​ : Feedback received is to try setting width/height properties on the video or adding CSS to control the size. Please try and share your views.
-Durgesh
fguerra
(To:dupatel)
Hi Durgesh,
Thank you for the answer,
I tried changing the size of the video in the video details and using CSS with the same results, the video did change the size but when it starts automatically goes to full screen.
This only happens with IOS devices, not with android so it seems that is something related to the device OS, I don't know if there is a property or style configuration I could apply to avoid this.
From my research it seems that using webkit-playsinline or drawImage() should solve the issue but not sure if this is supported by Studio or IOS.
Any further tips would be appreciated.
Felix
dupatel
(To:fguerra)
Felix Guerra​ : Thank you for sharing your observation and i will further check on this to get more details to you.
-Durgesh
dupatel
(To:dupatel)
Felix Guerra​: Please find the feedback recieved from R&D team -
"Backlog item added for enhancements to Studio & View to support this on iOS. Expect a combination of playsinline/webkit-playsinline & allowsInlineMediaPlayback would make it work."
Hope it helps.
-Durgesh
fguerra
(To:dupatel)
Hi Durgesh Patel,
Thank you for your follow-up, let see if they include this functionality soon.
