Creo Parametric Augmented Reality Log In
emartini
Hi everyone,
i can't log in to post AR experiences from Creo Parametric.
How can I proceed?
Ermes.
3 REPLIES 3
dupatel
(To:emartini)
@emartini Just wanted to know if you were able to login to this site before and did the issue started coming now? I would request to raise a PTC Tech support case to investigate and assist you further.
emartini
(To:dupatel)
Previously I had no problems accessing this portal.
Even answering directly to the link of the comunity I have the problem shown in the attached image
by accessing www.ptc.com support I have no problem.
Ermes
dupatel
(To:emartini)
@emartini  Thank you for confirming, and I am checking it internally with the right team. Meanwhile, we will create a support case as well as it helps us keeping track of the investigation/resolution.
