I have an issue while I running the setup.exe on Windows 10 64bits:
[25/06/2020 18:33:16] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
- Excepción de lectura del manifiesto desde https://studio-download.vuforia.io/downloads/Studio.application: puede que el manifiesto no sea válido o el archivo no se abra.
- Origen: System.Deployment
- Seguimiento de la pila:
en System.Deployment.Application.ManifestReader.FromDocument(String localPath, ManifestType manifestType, Uri sourceUri)
en System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirectBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
en System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
en System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
en System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
--- Fin del seguimiento de la pila de la ubicación anterior donde se produjo la excepción ---
en System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
en System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
--- Excepción interna ---
System.Xml.Schema.XmlSchemaValidationException
- El grupo de sustitución hace referencia a 'right', un elemento no declarado.
- Origen: System.Xml
en System.Xml.Schema.XmlSchemaValidator.SendValidationEvent(XmlSchemaValidationException e, XmlSeverityType severity)
en System.Xml.Schema.XmlSchemaValidator.RecompileSchemaSet()
en System.Xml.Schema.XmlSchemaValidator.Init()
en System.Xml.XsdValidatingReader.SetupValidator(XmlReaderSettings readerSettings, XmlReader reader, XmlSchemaObject partialValidationType)
en System.Xml.XsdValidatingReader..ctor(XmlReader reader, XmlResolver xmlResolver, XmlReaderSettings readerSettings, XmlSchemaObject partialValidationType)
en System.Xml.XmlReaderSettings.AddValidationAndConformanceWrapper(XmlReader reader)
I am not even able to start the installation process.
Hi @Casaga76 ,
Please review the steps given in the below article. Hope it helps to resolve the issue:
https://www.ptc.com/en/support/article/CS259459
I make the steps defined in the article CS259459 but they didn't solve my issue.
In addition, the errors described don't seem to be related to my problem...
Please, could you check it again?
Regards
@Casaga76 could you please share the studio log file to track the issue. Thank you!
Below the full log (sorry part is in Spanish):
INFORMACIÓN DE VERSIÓN DE LA PLATAFORMA
Windows : 10.0.18362.0 (Win32NT)
Common Language Runtime : 4.0.30319.42000
System.Deployment.dll : 4.8.3752.0 built by: NET48REL1
clr.dll : 4.8.4180.0 built by: NET48REL1LAST_B
dfdll.dll : 4.8.3752.0 built by: NET48REL1
dfshim.dll : 10.0.18362.1 (WinBuild.160101.0800)
ORÍGENES
Dirección URL de la implementación : https://studio-download.vuforia.io/downloads/Studio.application
RESUMEN DEL ERROR
Abajo se muestra un resumen de los errores; los detalles de estos errores se incluyen en el registro.
* La activación de https://studio-download.vuforia.io/downloads/Studio.application dio como resultado una excepción. Se detectaron los siguientes mensajes de error:
+ Excepción de lectura del manifiesto desde https://studio-download.vuforia.io/downloads/Studio.application: puede que el manifiesto no sea válido o el archivo no se abra.
+ El grupo de sustitución hace referencia a 'right', un elemento no declarado.
RESUMEN DE ERRORES DE TRANSACCIÓN DEL ALMACÉN DE COMPONENTES
No se detectó ningún error de transacción.
ADVERTENCIAS
No se generó ninguna advertencia durante esta operación.
ESTADO DE PROGRESO DE LA OPERACIÓN
* [05/07/2020 17:16:38] : Se ha iniciado la activación de https://studio-download.vuforia.io/downloads/Studio.application.
DETALLES DEL ERROR
Se detectaron los siguientes errores durante esta operación.
* [05/07/2020 17:16:38] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
DETALLES DE TRANSACCIÓN DEL ALMACÉN DE COMPONENTES
No hay información disponible sobre la transacción.
Have you tried the installation with Administrator user? To run the application as administrator, right click on the installer file and select 'Run as Administrator' option. Please let me know if it helped to resolve the issue.
Yes, I did it without success. Running as Administrator throws the same error.
Hi @Casaga76 ,
I have sent a private message requesting for a webex meeting to debug the issue. Kindly let me know your available time and email address to send the webex invitation. Thank you!
Does anyone have a resolution for this problem they can share? A team member of mine is experiencing the exact issue. Thanks!
