HTML button in 2D canvas
  • October 15, 2020
  • 4 replies
  • 2174 views
Hi everyone,
I want to disconnect my projects from "drag and drop" widget or buttons.
My idea is to try to implement all buttons/widget/popup with some html code, in this way all the experience will be managed with the javascript file.
Has anyone some tips?
Thank you
My guess is 'No'.
Widgets are essential to create 2D elements.
There is no control over HTML, only CSS.
Thank you for the clarification.
Into the net I found https://ionicframework.com/docs/api/. Is there any chance to use this api into Vuforia Studio?
One possilbe usage is to use $ionicPopup service -  here some examples
var my_msg_data={
 title: '', // String. The title of the popup.
 cssClass: '', // String, The custom CSS class name
 subTitle: '', // String (optional). The sub-title of the popup.
 template: 'This is component InfoView', // String (optional). The html template to place in the popup body.
 templateUrl: '', // String (optional). The URL of an html template to place in the popup body.
 okText: '', // String (default: 'OK'). The text of the OK button.
 okType: '', // String (default: 'button-positive'). The type of the OK button.
$scope.app.TestPopup=function(my_comp){
 my_msg_data['title']='Test Popup';
 my_msg_data['template']="Test Pupup funciton = " + my_comp;
 my_msg_data['okText']='Acknowledge';
 my_msg_data['okType']='button-balanced';
 var alertPopup= $ionicPopup.alert( my_msg_data);
 alertPopup.then(function() {console.warn("then branch of popup called");} );
$scope.app.TestSecondPopup= function(){
$scope.$applyAsync(function() {$scope.app.showPopupMore();}, 3100);
// Triggered on a button click, or some other target
$scope.app.showPopupMore = function() {
 $scope.data = {};
 // An elaborate, custom popup
 var myPopup = $ionicPopup.show({
 template: '<input type="password" ng-model="data.wifi">',
 title: 'Enter Wi-Fi Password',
 subTitle: 'Please use normal things',
 scope: $scope,
 buttons: [
 { text: 'Cancel' },
 text: '<b>Save</b>',
 type: 'button-positive',
 onTap: function(e) {
 if (!$scope.data.wifi) {
 //don't allow the user to close unless he enters wifi password
 e.preventDefault();
 } else {
 return $scope.data.wifi;
 myPopup.then(function(res) {
 console.log('Tapped!', res);
 $timeout(function() {
 myPopup.close(); //close the popup after 3 seconds for some reason
 }, 15000); //resticted to 15 seconds
 // A confirm dialog
 $scope.showConfirm = function() {
 var confirmPopup = $ionicPopup.confirm({
 title: 'Consume Ice Cream',
 template: 'Are you sure you want to eat this ice cream?'
 confirmPopup.then(function(res) {
 if(res) {
 console.log('You are sure');
 } else {
 console.log('You are not sure');
 // An alert dialog
 $scope.showAlert = function() {
 var alertPopup = $ionicPopup.alert({
 title: 'Don\'t eat that!',
 template: 'It might taste good'
 alertPopup.then(function(res) {
 console.log('Thank you for not eating my delicious ice cream cone');
and test in preview mode
