HoloLense: using multiple sequences
DF_9703795
Hi everyone,
in Creo Illustrate I created a .pvz file with:
Figure 1: Sequence "Play 1"
Figure 2: Sequence "Play 2"
Now I want to start each sequence with a 3D Button.
I linked "Play 1" to the first 3D-Button - works fine. But HoloLense doesn't have a "Sequence list" so how can I tell the second 3D-Button that he should start "Play 2"?
Thanks for your help!
sebben
(To:DF_9703795)
you can use this function:
$scope.SetSequenceAndPlay = function(NewSeqName)
  console.log($scope.app.view["Home"].wdg["model"].sequence);
  $scope.$broadcast('app.view["Home"].wdg["model"].svc.reset');  // Stop playback, if needed, of current sequence
  $scope.app.view['Home'].wdg['model']['sequence'] = NewSeqName; // Assign new sequence to the model
  $timeout(function() {
    $scope.$broadcast('app.view["Home"].wdg["model"].svc.play'); // Add some delay (in msec) to load the sequence, then play
  },1000);
Call it from the Play buttons  with the correct path to the sequence. You can find the path when you select a sequence, call the function and check the console of your browser. It should be something like:
app/resources/Uploaded/MODELNAME/l-Creo 3D - Figure 1.pvi
So call for example SetSequenceAndPlay("app/resources/Uploaded/MODELNAME/l-Creo 3D - Figure 1.pvi");  in the Click event of the Play1 button.
I hope this helps.
sebben
(To:DF_9703795)
  },1000);
I hope this helps.
