How to check attributes or method associated with application parameter ?
Parimal_Sahu
7-Bedrock
In vuforia studio,Is there anyway to check attributes or method associated with application parameter.
example :- In "$scope.app.params" , after params what all possible attributes are available.
Hello Parimal,
Why using a Parameter in a such case?
It is possible to do a binding directly to Properties of 3D Model or to create a Javascript function to change value of any Property of a 3D Model.
It will be more useful for a developer when using binding and Application Parameter.
Best regards,
Samuel
3 REPLIES 3
To be honest, I am not sure to understand that is the need.
Normally, as developer, we know Application Parameter created in a Project in Vuforia Studio.
  • What is the needs or the problem ?
  • What I have misunderstood ?
Best regards,
Samuel
Hi Samuel,
Thanks for the reply,
In Vuforia studio, I have approx 30-40 model (small mechanical parts). now for controlling properties like visibility, opacity and Coordinates always need to bind with application parameter manually by drag and drop.
For a developer which is very time consuming, so thought if somehow I can create multiple Application parameter and bind in js.
Hello Parimal,
Best regards,
Samuel
