How to read json file inside Vuforia Studio
Aditya1702
Hi everyone,
I have a json file which has attribute values of a widget in key value pair for eg.
"attributes": {
                "twx-widget": "",
                "widget-id": "p2a",
                "widget-name": "p2a",
                "is-widget-container": "true",
                "src": "Uploaded/pin.pvz",
                "scale": "0.5",
                "x": 0.44480000000000003,
                "y": 0.6587000000000001,
                "z": 0.603,
                "rx": "0",
                "ry": "0",
                "rz": "0"
"attributes": {
                "twx-widget": "",
                "widget-id": "p2b",
                "widget-name": "p2b",
                "scale": "0.5",
                "z": 0.611,
                "rx": "0",
                "ry": "0",
                "rz": "0"
How can I assign this value to a widget in Vuforia Studio?
Thanks in advance.
Aditya Gupta
Similar discussion - "How to include a .json file from Vuforia Studio resources": https://community.ptc.com/t5/Vuforia-Studio/How-to-include-a-json-file-from-Vuforia-Studio-resources/td-p/729025
Hi @VladimirN ,
I tried the link you provided but was not able to read the data from the json file.
Can you please explain in more detail about how can I fetch data from json file and change the widget values.
Thanks in advance.
Aditya Gupta
Hi @Aditya1702 ,
I woud think - when the data is assigned to the scope variable myJson
then you can access it
$scope.myJson= data
e.g. you want to access the x,y and z value
but first to correct that print should be an array so let say the variable name is then $scope.myJsonArray ...
$scope.myJsonArray=["attributes": {
                "twx-widget": "",
                "widget-id": "p2a",
                "scale": "0.5",
                "z": 0.603,
                "rx": "0",
                "ry": "0",
                "rz": "0"
"attributes": {
                "twx-widget": "",
                "widget-id": "p2b",
                "scale": "0.5",
                "z": 0.611,
                "rx": "0",
                "ry": "0",
                "rz": "0"
so now when we want to access the x for the first element and set it to value e.g.
$scope.myJsonArray[0]['attributes'].x=0.46
//or
$scope.myJsonArray[0].attributes.x=0.46
//or
$scope.myJsonArray[0]['attributes']['x']=0.46
and let say to set Y valuel of the second element it should be  something like that :
$scope.myJsonArray[1]['attributes'].y=0.77
//or
$scope.myJsonArray[1].attributes.y=0.77
//or
$scope.myJsonArray[1]['attributes']['y']=0.77
