How to use Application Parameter's Thing Template in studio
Desai
11-Garnet
What is the purpose of using Thing Template as an application parameter in Thingworx studio?
How to dynamically the properties of the Thing Template in studio?
I have added Thing Template's service "GetImplementingThings" in studio but I am unable to fetch the properties stored in the "Things" which extends the Thing Template.
9 REPLIES 9
mnarang
(To:Desai)
Application parameters are parameter which you can create and use in your JS code in studio .For example i created an application parameter with name count and can use this variable in my JS like $scope.app.params.count = 0
If you want to access properties/services that are there in your hosted Thingworx (Which is connected to your studio)  you can click on the (+) sign of external data below application parameter and from there you can fetch Thingname/Template name and this will give you a list of properties/services which you have created or inbuilt to the template .From there you can get data in your Studio .
Thanks ,
Mukul Narang
Desai
11-Garnet
(To:mnarang)
How to use the "Thing Template" application parameter in studio.
How to load the Thing Template Properties in the studio?
mnarang
(To:Desai)
If you want to access properties/services from the ThingTemplate Which is there in Thingworx (Hosted thingworx which is connected to Studio) .Then you need to click on the external data (+) sign and select the template/thing from there and select properties or services which you want to use in Studio .I have also attached the screenshots for this .
mnarang
(To:mnarang)
One more screenshot .
Thanks ,
Mukul Narang
Desai
11-Garnet
(To:mnarang)
I have created a Thing Shape Named "Acceleration" which has properties "Velocity" and "current".
Then I have created a Thing Template named "Acceleration_TT" which has "Implemented Shape" as "Acceleration".
Now I am calling "Acceleration_TT" in the external data. But I am unable to get the properties "Velocity" and "Current". So how do I call the properties in the Thingworx studio?
mnarang
(To:Desai)
Can you paste the thingworx url where you are creating Template and Shape ? Just want to confirm that this is the thingworx which is in place with Studio trail .
Desai
11-Garnet
(To:mnarang)
mnarang
(To:Desai)
This URL is fine .When you are clicking on the external data and selecting the Template from the list so there is nothing under properties ,right ? But after clicking on the Template from the list ,can you check the Studio Logs .There might be some permission issue from the Thingworx side ,that can be a reason that Studio is not able to read the properties from Thingworx .
Desai
11-Garnet
(To:mnarang)
Only for the Thing Template I am unable to fetch the properties. I can fetch properties in "Things". I do not think there is an issue with the permission.
Thanks.
