Javascript async functionality execute code step-by-step
KanivetsAV
7-Bedrock
Hello everybody!
Is there a way to sequentially execute javascript code in vuforia?
I have a function in which I need to perform a series of actions in a clear order:
1) Call the service and get the data
2) Analyze data from the service
3) Depending on the data analysis, show or hide some elements of the vuforia interface
If i write the code like this:
// Call service
$scope.ServiceCall = function () {
     twx.app.fn.triggerDataService("VuforiaThing", "Service");
// Anylaze data
$scope.DataAnalyze = function () {
     if ($scope.app.mdl['VuforiaThing'].svc['Service'].data.current['OperationStatus'] == "status"){
         $scope.app.params.testparam = true;
     } else {
         $scope.app.params.testparam = false;
//Manipulate UI
$scope.ManipulateUI = function () {
     if ($scope.app.params.testparam == "true"){
         $scope.view.wdg['WidgetID']['visible'] = true;
     } else {
         $scope.view.wdg['WidgetID']['visible'] = false;
// Execute code after  view entry
$scope.$on('$ionicView.afterEnter', function() {
     $scope.ServiceCall();
     $scope.DataAnalyze();
     $scope.ManipulateUI();
sometimes it turns out that step 2 is performed earlier than 1 and then an incorrect analysis occurs, since there is no data and, accordingly, at step 3, I perform erroneous actions on the interface elements.
If i try to use "async function" vuforia say
! 'async function' is only available in ES8 (use 'esversion: 8').
I find some solutions like this
but it does not working in Vuforia.
Hello everybody!
Seems i found solution.
First of all we need on our "screen.js" paste such code comment:
/*jshint esversion: 8 */
After that manipulation vuforia studio don't alert async js functions.
example1:
$scope.$root.$on('SomeTwxService-end', async function(evt, arg) {
    await $scope.Func1();
    await $scope.ManipulateUI();
    await $scope.Func2();
    await $scope.Func3();
example2:
$scope.OpCntrlStateChangedCheck = function () {
    var step1_value;
    var step2_value;
    var step3_value;
  	var p1 = new Promise((resolve, reject) => {
    	step1_value= angular.element(document.querySelectorAll('twx-widget[widget-id=\"SomeID1\"] twx-widget-content div label input'));
      	resolve();
    var p2 = new Promise((resolve, reject) => {
    	step2_value= angular.element(document.querySelectorAll('twx-widget[widget-id=\"SomeID2\"] twx-widget-content div label input'));
      	resolve();
    var p3 = new Promise((resolve, reject) => {
    	step3_value= angular.element(document.querySelectorAll('twx-widget[widget-id=\"SomeID3\"]'));
      	resolve();
	Promise.all([p1, p2, p3]).then(value => {
	    if (SomeValue == "learn") {
       		for (var x0=0; x0 < $scope.view.wdg['repeater-2']['data'].length; x0++) {
				Step1_value[x0].disabled = true;
        } else {
       		for (var x1=0; x1 < $scope.view.wdg['repeater-2']['data'].length; x1++) {
				Step1_value[x1].disabled = false;
        for (var x2=0; x2 < $scope.view.wdg['repeater-2']['data'].length; x2++) {
            if (step1_value[x2].checked == step2_value[x2].checked) {
                step3_value[x2].className = "ControlValueCheckbox checkbox-balanced";
            } else if (step1_value[x2].checked != step2_value[x2].checked) {
                step3_value[x2].className = "ControlValueCheckbox checkbox-assertive";
I tested functionality in the vuforia studio and on mobile vuforia view application seems to work fine.
It may be useful for other community members.
2 REPLIES 2
pandersson
(To:KanivetsAV)
Have you tried to listen on serviceInvokeComplete?
Like this example.
$scope.$on('getModelURL.serviceInvokeComplete', function() {
$scope.view.wdg['model-4']['src'] = $scope.app.mdl['remoteDesignShareUtils'].svc['getModelURL'].data.current['result'];
$scope.app.mdl['remoteDesignShareUtils'].svc['copyRep2FileRepowJSON'].data.current['result'];*/
Hello everybody!
example1:
example2:
    var step1_value;
    var step2_value;
    var step3_value;
      	resolve();
      	resolve();
      	resolve();
        } else {
