I'm trying to link two different experiences together using a button that shows up at the end of one experience and, when pressed, launches the next. I thought that the method that I had used to link to other types of media and web pages would work, but apparently not. What am I doing wrong? Here's the code I'm using for reference:
$scope.nextPhase = () => {
let nextPhase = $sce.trustAsUrl('experience link');
open(nextPhase);
}Thanks in advance for any help.
Hello Ike@ACE ,
you can use
window.location.replace(url);
for this use case. the url should be defined as the url you get from Vuforia Studio, when you access the Share button within the Vuforia Studio design canvas.
Hello Ike@ACE ,
you can use
