Hi ,
In Vuforia studio when I am using Model Target for Holoens, Tracking and size are correct as per real Hardware, but as my view changes the 3d Model is not stationary, similar like using on Image target.
Is there any way to get Stationary properties for Model Target?
Hi @Parimal_Sahu,
so far, I know it is possible to set stationary property on the model target.
So, for that what could make is more stable I want to refer to the post
Whit java script we could set the following 3D Container widget properties additional to the GUI
$rootScope.$on('modelLoaded', function() {
$scope.check_if_works=false
$scope.setWidgetProp('3DContainer-1','enabletrackingevents',true);
$scope.setWidgetProp('3DContainer-1','dropshadow',true);
$scope.setWidgetProp('3DContainer-1','extendedtracking',true);
$scope.setWidgetProp('3DContainer-1','persistmap',true);
So maybe the extendedtracking and persistmap properties could have some positive effect in your case
Thanks Roland for reply,
I was looking solution for Hololens and 3d container of 3d Eyewear has very limited properties available.
so even I have your code the result did not improved because it does not have extendedTracking, enableTrackingevents
Yes , correct ! I am sorry, it was mistake in my post - the first sentence should mean „ so far I know, it is NOT possible to set stationary property on model target" –
I just wanted to mention the properties we can set with javascript with the hope that it could have some positive effect in your case .
