Hi Guys,
When I use Model Item, it Works very well on Android devices and browser preview,
But the same model item does not work in IOS devices.
I used the following steps:
1 - Create a model Item
2- Select the pink color
Result in Browser preview
Result in IOS Device
Does anyone know a way to work on all devices?
Any help to fix this issue would be welcome.
Hi Monica. What device and iOS version are you using? I have been unable to reproduce this locally.
The problem stopped happening, I believe it was some mistake of mine.
Thank you gays.
