Can anyone help me how I am able to modify values in thingworks with vuforia studio? Is it possible? As you see in attached picture only one direction is available.
Thanks in advance
Janos
Hi @Janos1987 ,
yes is possible. So far I remember two methods to set data in thingworx
1.) using a thingworx service with argument which will set the data to thingworx thing .
Here is an example with a repeat widget which togle the visibility of component
The repeater click event will call the service setCompIdVisibility. The repeater item Comp_id is bind to the method paramater. So when we click the repeater for a selected item it will call the service setCompIdVisibilitysetCompIdVisibility with Comp_id as argument and will change the visibility status in the Thingworx this is a thing property
And in preview mode it looks like:
2.) using some Rest API which will set the data.
Here is an example of similar service but using a REST API call
$scope.setCompVis = function(Comp_id,val) {
if(val==true)
var serviceStr='setCompIdVisibility';
else
var serviceStr='unsetCompIdVisibility';
var req = {
"method":'POST',
"url":'/Thingworx/Things/DoorControlProces/Services/'+serviceStr+'?Appkey="bfXX15Xf-cfnd-5538-98ft-7201d728457" HTTP/1.1',
"Host": 'XXXXXXXXX.studio-trial.thingworx.io:8443',
"Content-Type": 'application/json',
"AppKey": "bfXX15Xf-cfnd-5538-98ft-7201d728457",
"Cache-Control": 'no-cache',
"Postman-Token": '99e788f6-XXXX-XXXX-555c-b87f451dc144',
"headers": {
"authorization": "Basic Og==",
"content-type": "application/json",
"cache-control": "no-cache",
"postman-token": "c1871006-XXXX-0ae1-1002-092221d9dtnf"
"processData": false,
"data": "{\n\t\"Comp_id\":\""+Comp_id+"\"\n\t\n}"
console.log("$scope.setCompVis");
console.warn(req);
$http(req).then(
function(response) {;},
function(response){;}
};//finished $scope.setCompVis
OK , it looks a little complicated but it is easy to generate this code if you use a tool like the Google POSTMAN where first you can test the Rest API request with the user Interface
And later you can generate JavaScript or node.Js programming code . The mention sample funciton above was created using this tool. Here the JS function setCompVis() has 2 arguments
val - /true/ false -> depending on this value it will call different services to set (true to visible -> serviceStr='setCompIdVisibility' ) unset (false to invisible - will call serviceStr='unsetCompIdVisibility') the visiblity property of component
cmp_id -> this is the component id (syntax what is used for the modelitem widget property-> Component Occurrence
So that the simple call of the function:
$scope.test_fnct = function(){
$scope.setCompVis("/46/390",true);
it will call the service setCompIdVisibility of the thing which have property Comp_id ="/46/390" and set the property visible to true. In this case this is the component "vertical_beam1"
Hi @Janos1987 ,
if(val==true)
else
var req = {
"method":'POST',
"headers": {
console.warn(req);
$http(req).then(
Hi @RolandRaytchev ,
many thanks it helped me a lot. I used the first instruction of yours. I run a service with Vuforia studio and it overwrites the value on the thingworx. It is so easy but i am a beginner :). Thanks a lot again.
Janos
