No preview seen in Thingworx studio
SureshPerinjery
11-Garnet
With the latest updated version of Thingworx studio when a new experience is created , the preview does not show anything. Similarly after publish, in Thingworx view when the Thingmark is scanned, the experience name pops up for selection but no experience is shiwn
3 REPLIES 3
What OS are you using? Is it possible to share the ThingMark you are scanning?
Hi Tara,
Thank for you reaching out. I realized that there was an error in the java script put in Home.js and that's why the preview was not coming.
rectified the error and it started working. Is it a normal behaviour to not show preview if there is an error in java script?
Suresh
Hi Suresh,
Glad to hear that you are now able to view your experience! I ran a few test cases locally and found that the preview will show depending on what the JS error is. For instance, I misspelled a variable and was able to view all aspects of the experience within the preview. I then misspelled an application parameter and that portion of the experience did not show within preview. Let me know if you have any additional questions.
Tara
