Hello Everyone!
A couple weeks ago the vuforia studio app mentioned there was an update available. So I went and proceeded with the update, and ever since then, my Vuforia will not open. I checked the task manager and noticed that 'Node.JS: Server-side Java Script Suspended.'
Even if I go into the resource monitor and resume it, the Vuforia App does not open. I only noticed this problem since the update.
I have tried uninstalling and reinstalling - in which the APP was able to load, only once with no issue, but the next day the same error message occured.
Any assistance would be greatly appreciated.
Thank you
I think I am all set for now, i did a clean install of windows on a different pc - and the program seems to be opening and functioning now.
Thank you for your assistance.
More details here about how to look in this tool :
Best regards,
Samuel
I have copied the log from Vuforia Studio, please see below:
[2019-10-11T12:20:33.796Z] Status Message: Getting ready...
[2019-10-11T12:20:33.796Z] Starting node.exe
[2019-10-11T12:20:38.150Z] info: [twx-studio:index] Studio Version 8.5.0.4481
[2019-10-11T12:20:38.376Z] info: [twx-studio:initializer] Node version: 10.15.3
[2019-10-11T12:20:38.379Z] info: [twx-studio:initializer] studio launched with the following arguments: { _: [ 'C:\\Users\\mryman\\Documents' ],
'$0':
'..\\..\\..\\..\\..\\..\\Roaming\\VuforiaStudio\\studio-download.vuforia.io\\dist\\server\\index.js' }
[2019-10-11T12:20:38.381Z] info: [twx-studio:initializer] studio dir: C:\Users\mryman\Documents\VuforiaStudio , home dir: C:\Users\mryman\Documents
[2019-10-11T12:20:38.387Z] info: [twx-studio:builderSettingService] C:\Users\mryman\Documents\VuforiaStudio\builder-settings.json was not found, creating it now
[2019-10-11T12:20:45.093Z] info: [twx-studio:gitUtils] nodegit is not installed.
[2019-10-11T12:20:45.142Z] info: [twx-studio:ar-extension:upgrade] ar-extension version 8.5.0.4481 (1.43.1616)
[2019-10-11T12:33:43.922Z] Studio 8.5.0.4481
[2019-10-11T12:33:43.970Z] Status Message: Getting ready...
[2019-10-11T12:33:43.970Z] Starting node.exe
[2019-10-11T12:33:46.006Z] info: [twx-studio:index] Studio Version 8.5.0.4481
[2019-10-11T12:33:46.098Z] info: [twx-studio:initializer] Node version: 10.15.3
[2019-10-11T12:33:46.100Z] info: [twx-studio:initializer] studio launched with the following arguments: { _: [ 'C:\\Users\\mryman\\Documents' ],
'$0':
[2019-10-11T12:33:46.102Z] info: [twx-studio:initializer] studio dir: C:\Users\mryman\Documents\VuforiaStudio , home dir: C:\Users\mryman\Documents
[2019-10-11T12:33:49.192Z] info: [twx-studio:gitUtils] nodegit is not installed.
[2019-10-11T12:33:49.231Z] info: [twx-studio:ar-extension:upgrade] ar-extension version 8.5.0.4481 (1.43.1616)
For the Windows Event Log - I do apologize, I could not specifically find anything with the Node.JS.
Please let me know if this info helps.
Thank you!
I have some questions to investigate deeper :
Thanks in advance for your feedback.
Best regards,
Samuel
