Showing animation in select widget
SOLVED
Aquamarine
When I click on select widget, the drop-down just pops up. Instead I want it to slide and then show the options. Any idea how it can be achieved?
Re: Showing animation in select widget
I wrote you this project, just to make you understand how you have to do to have that kind of effect.
I hope to be proved helpful.
Giuseppe
11 REPLIES 11
Hi @vivekse ,
I am not sure if we could achieve this by using some style. Actually if you could get similar functionality for the html select -element by using any styles sheets /css - this should also work here – so the same class definition could be also used in Studio.
Alternatively, I think a popup with list element could achieve similar functionality as shown on the picture below:
Please have a look at this video through the link provided below.
https://www.linkedin.com/posts/ptcinc_industrialengineering-ar-activity-6613072450072772608-fjg3
I want to understand how such interface is possible?
thanks, yes this seem to be Vuforia view on IOS , I belive.
I think this is a horizontal tab widget with a list widget on it or also possible repeater could be used.
Actually I tried to do as per your suggestion but still I am unable to achieve that. Any other suggestion would be highly appreciated.
I created the Howden diaphragm compressor experience in the video that you linked to.  The menu that comes out from the right side of the screen is made using a panel with a grid inside the panel.  The flyout effect was created with CSS.
I first of all I would like to thank you for replying to my query but again I tried to do it and was not able to achieve that.
Its my humble request if you could link any project related to this so that I can refer to that project directly.
Use this CSS applicate to class of panel .
and turn on or off visibility of widget to animate Panel width a click Event or js call on Button or other Widget.
/////// Js to show/hide a pannel
$scope.show=function() {
$scope.view.wdg['name of widget']['visible']=!$scope.view.wdg['name of widget']['visible'];
//// CSS for effect
.swing-left-bck {
-webkit-animation: swing-left-bck 2s;
animation: swing-left-bck 2s; }
.swing-left-bck.ng-hide {
-webkit-animation: swing-right-bck 2s;
animation: swing-right-bck 2s; }
@-webkit-keyframes swing-left-bck {
0% {
-webkit-transform: rotateY(180deg);
-webkit-transform-origin: left;
transform-origin: left; }
100% {
-webkit-transform: rotateY(0deg);
transform-origin: left; } }
@-webkit-keyframes swing-right-bck {
0% {
100% {
i hope to help you.
Giuseppe
Giuseppe
I can't give you that project because it has customer data in it.  What is it that you are having trouble with specifically?
Topics available:
AR/VR for Data Optimization AR/VR for Security and Control AR/VR for Inspection
