Turn 3D-Picture On and Off at a specific Step
Yasar
Hi Guys,
I'm new to Vuforia Studio so i try to figure out, how some mechanics work.
What I want to do is, I Want a 3D-Picture turn on, at for example by Step 5 and turn off by Step 8.
I already can select a sequence from a 2D-Select Widget, press play and see the animations.
$scope.setsequenceList = function(){
  $scope.app.params.sequenceList = [
      "display":"Item1",
      "value":"app/resources/Uploaded/l-Creo%203D%20-%20Sequence%202.pvi"
$scope.setsequenceList();
Now only my 3D-Picture "Warning" is missing. I already found some guides but i'm not able to transfer the solutions into my problem (Beginner Level with Coding).
https://community.ptc.com/t5/Studio/Play-specific-step-of-PVI-sequence-at-studio/m-p/552906#M3362
and
https://community.ptc.com/t5/Studio/How-to-turn-3D-image-files-on-and-off-when-using-a-2D-select/m-p/611996
If you can help, I would appreciate 🙂
ytella
(To:Yasar)
Hi @Yasar ,
One of the ways to implement this scenario is as follows:
  • Drag and drop a 3DImage on to the canvas
  • Add the resource by clicking on the + sign next to Resource Property
  • Uncheck the Visible property of the 3DImage
  • Copy and paste the below contents in the Home.js
    • $scope.$on('$ionicView.afterEnter', function(event) {
      let view = event.targetScope.view;
      console.log('viewContentLoaded', view);
      $scope.$watch('view.wdg["model-1"].currentStep', function (stepVal, oldVal) {
      console.log('model step changed', stepVal);
      $timeout(function () {
      $scope.changeImage(stepVal);
      }, 10);
      $scope.changeImage = function (step) {
      if (step == 5)
      $scope.view.wdg['3DImage-1'].visible = true;
      if (step == 😎
      $scope.view.wdg['3DImage-1'].visible = false;
    • This will automatically call the changeImage function and will show/hide the image when the if condition is met
Hope this helps!
ytella
(To:Yasar)
Hi @Yasar ,
      }, 10);
      if (step == 5)
      if (step == 😎
Hope this helps!
Yasar
(To:ytella)
@ytella Thank you very much!
It worked perfectly 🙂
