May 30, 2019 3:12 PM UTC
How to turn 3D image files on and off when using a 2D select widget
I am using a 2D select widget to control the sequence being played.  I would like to be able to display different 3D images based on this selection.
tmccombieAnswer
May 30, 2019 8:45 PM UTC
Here's an example of doing this with 3 different sequence options. You'll have to update the widget IDs to match your widgets.
$scope.checkSequence = function(){
 var sequenceValue= $scope.app.view['Home'].wdg['select-1']['value'];
 console.log(sequenceValue);
 var sequenceList = $scope.app.view['Home'].wdg['select-1']['list'];
 //console.log(sequenceList[0].filename);
 for (i = 0; i < sequenceList.length; i++){
 var sequence = sequenceList[i].filename;
 if (sequence == sequenceValue){
 switch(i){
 case 0:
 $scope.setWidgetProp('3DLabel-1','visible', true);
 $scope.setWidgetProp('3DImage-1','visible', false);
 $scope.setWidgetProp('3DImage-2','visible', false);
 break;
 case 1:
 $scope.setWidgetProp('3DImage-1','visible', true);
 $scope.setWidgetProp('3DLabel-1','visible', false);
 break;
 case 2:
 $scope.setWidgetProp('3DImage-2','visible', true);
 break;
 default:
 console.log('in show/hide images');
Call this function on the "Value Changed' Event for your 2D selector
tmccombie21-Topaz IAnswer
 switch(i){
 case 0:
 break;
 case 1:
 break;
 case 2:
 break;
 default:
May 31, 2019 1:17 PM UTC
Thank you for your help but I cannot get this to work.  I wonder if the reason this is not working due to the way I am doing my select widget.  My widget is setup like this.  https://community.ptc.com/t5/Studio/Select-Widget-default-value/m-p/611653
Jun 4, 2019 2:28 PM UTC
The difference is how you have the file names declared in your JSON. In my example i was using 'filename' but you are using 'val'. In the for loop, change the sequence variable declaration to this:
var sequence = sequenceList[i].val;
That should fix it.
