Video widget in iOS
mziemniewicz
9-Granite
Video widget in iOS
Hello, I'm trying to use Video widget with mp4 file from experience server.
when I do:
$scope.setsrc=() => {
$scope.view.wdg['video-1'].videosrc='/Thingworx/FileRepositories/UL.FileRepository/Vid_20190531_125615_1.mp4';
And then hit play it works fine in preview and Android, but on iOS I just can't make it work. (when I click play widget resets)
Does anyone have an idea how to solve this?
Kind regards
1 ACCEPTED SOLUTION
Hi @mziemniewicz  and @ClayHelberg,
I think there is another solution I just tested which could be more independent  from the visibility of the Thingworx server. So, for this way you need solely the access of the Experience server
Follwoing steps:
1.) checking the path of the path on the repository:
2.) set the permission of the service LoadBinary of the repositorything  to run for 'es-public-access'
3.) add the service in the External Data in Vuforia Studio project :
4.) add e.g. a button click event to the video widget play service:
5.) add the following javaScript code;
////////////////////Issue with read video from repository
$scope.GetVideoFromTwxRepository = function(path) {
 $scope.$applyAsync(function() {
   $rootScope.$broadcast('app.mdl.CAD-Files-Repository.svc.LoadBinary',
                          {"path":path}
                         );}   ,500 );
  console.log("after calling GetImageFromTwx");
  $scope.$on('$ionicView.afterEnter', function()  {
  // register the LoadBinary-complete event + callback
  $scope.$root.$on('LoadBinary-complete', function(event, args) {
  console.log("LoadImage-complete event");
 console.log("name="+event.name)
 console.warn(args.data);
 console.warn(args.data[0]);
  var ret_str='data:video/mp4;base64,'+args.data[0].Content;
   $scope.view.wdg['video-1']['videosrc']=ret_str;
console.warn($scope.view.wdg['video-1']['videosrc'])
  //call the function to laod the mp4 file to video source of the video widget
$timeout( function () {$scope.GetVideoFromTwxRepository(
'/web/c-belt-converyor.mp4'
);},500);
6.) Test it in preview and on mobile device- I tested in Android and IOS Ipad 6 - and it was working fine
6 REPLIES 6
Hi @mziemniewicz,
what is the path what you use  here for the setting of the videosrc property ? : '/Thingworx/FileRepositories/UL.FileRepository/Vid_20190531_125615_1.mp4'
Is this a local folder in your project or did you try to use /as the name says/ a FileRepositriy from Thingworx?
the full path is like:
where http://mycloudexperienceservice.com:8080/ this is the same address for Thingworx and the experience service of this particular experience.
Is it possible on your IOS device to play it from there/the mention repository link/ in other app or browser?
I found that in order to access content in a File Repository thing, I had to add the es-public-access appKey to the URL, along these lines:
$scope.GRAPHIC_REPOSITORY_URL = "https://vmqlbmkm.studio-trial.thingworx.io:8443/Thingworx/FileRepositories/MyGraphicStore/";
$scope.makeGraphicHref = function(id) {
  var appkey = "?x-thingworx-session=true&appKey=4xxxxxxxxxxxxxxxxxxxxxxxxxx";
  return $scope.GRAPHIC_REPOSITORY_URL + id + appkey;
Follwoing steps:
                          {"path":path}
                         );}   ,500 );
);},500);
Thank you so much! This solution is the only one that works perfect! 🙂
