Vuforia Studio Expereoence server model target poblem
Milliau
6-Contributor
When i tried my program to publsih on the test server it works, but on the server from my univeristy not.
I set the experience server correctly but when ich try to share the programm i get following error in the protocol pf vuforia studio:
2019-03-07T11:37:01.500Z] error: [twx-studio:tgt-gen.img] Response code 403
[2019-03-07T11:37:01.500Z] error: [twx-studio:tgt-gen.img] Could not retrieve signature,  {"message":"Insufficient permissions to access resource","errorCode":403,"error":{}}
[2019-03-07T11:37:01.500Z] error: [twx-studio:tgt-gen.img] Failed to generate the data set for model VuforiaStudio\Projects\NEw_Dectection_mitDH_late\dist\app\resources\Uploaded\bearbeitetohne Werkzeug.pvz undefined
[2019-03-07T11:37:01.501Z] error: [twx-studio:projectHelper] publishTask error for project NEw_Dectection_mitDH_late { Error: Publish failed, issue generating model target information
    at _Error (VuforiaStudio\studio-download.vuforia.io\node_modules\target-generator\lib\modelTargets.js:25:17)
    at ModelTargetGenerator.generateDataSet (VuforiaStudio\studio-download.vuforia.io\node_modules\target-generator\lib\modelTargets.js:204:13)
    at process._tickCallback (internal/process/next_tick.js:68:7) i18n: true }
[2019-03-07T11:37:01.501Z] error: [twx-studio:api] Error occured while publishing project NEw_Dectection_mitDH_late { Error: Publish failed, issue generating model target information
I hope someone can help me with this thanks
sdidier
(To:Milliau)
I found more details in this article;
https://www.ptc.com/en/support/article?n=CS279248
Model Target should be supporter for On-Premise Vuforia Experience Service since 8.3.4.
But, in configuration.json file, the mth.disable should be set to false.
  • Does this parameter has been enabled in Experience Service ?
Best regards,
Samuel
sdidier
(To:Milliau)
Hello Milliau,
The error messages seem very similar to this thread :
https://community.ptc.com/t5/Studio/can-not-publish-experience-with-model-target/td-p/536438
On the Vuforia Experience Service from your university might be in an old version where Model Target is not supported.
  • What is the version of this Experience Service ?
Best regards,
Samuel
Milliau
6-Contributor
(To:sdidier)
Hello Samuel,
thanks your your answer. It should be the version 8.3.8 is there somewhere an information which version give support for model target tracking?
Milieu
sdidier
(To:Milliau)
Best regards,
Samuel
