Vuforia Studio taking time to update data & Reconnecting error
Swapnil_More
Hey,
I am working on project in which I'm using multiple popups & labels(near about 40).
Problem is that whenever I am updating or adding anything to VS project it's taking time to update and after few minutes it's showing reconnecting vuforia studio.
I'm using Google Chrome 87.X.X it's up-to-date.
Can anyone tell me why this issue might arise?
Swapnil More
corrected  the project - toggle will work now
4 REPLIES 4
Hello @Swapnil_More ,
unfortunately I never tried to used so much popup widget so that I am not sure that there could be possible some issue when we use a large number of popups, I am not sure.
So- is possible to provide an example where we can check the issue more detailed? Respectively to report it to R&D if we can detect an issue.
or
possibly we can try a way to use smaller number of popup widgets
-e.g. to call some $ionicPopup. popup dialogs instead where we can make the appearance of the popup more flexible by the used html template
Thanks for reply.
I can't show HTML or iconic popups because the content in the popup is too much.
Please find attached sample project for reference.
In attached project whenever I'm adding something in popup it's showing reconnecting error.
Swapnil More
I did attached a demo project - where I modified your project - using javascript approach, please, see also  the post: https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Studio-lagging-while-building-project/m-p/704789#M9118
