Dec 25, 2020 5:35 AM UTC
Vuforia Studio lagging while building project
Hey,
I am using the latest version of VS 8.5.15.4805. I'm creating a project in which I have to include more than 40 popups, but when I create this It's start lagging and it shows a "Vuforia Studio reconnecting please wait" error.
I have tried many ways but have not been able to solve this problem.
@RolandRaytchev  Please help me I stucked on this from last 1 week.
Jan 25, 2021 2:32 PM UTC
corrected the project - toggle widget will work now
Jan 11, 2021 7:48 PM UTC
- issue is reproducible in preview or mobile or both
- actually the most popups should be hidden and only one popup should be active at the same time. I have no idea what should happen   when you call 2 different popups at the same time
Also, the widget popup type floating popup or Modal could be relevant
- if you have situation that you opened many popups because of some app synchronization reasons  you can try first to closed all e.g. mentioned in the post https://community.ptc.com/t5/Vuforia-Studio/Vuforia-Studio-Close-All-Popups/m-p/682310#M8668
Jan 12, 2021 4:11 AM UTC
Thanks for reply.
I'm showing only one popup at a time.
Please find attached sample project for reference.
In attached project whenever I'm adding something in popup it's showing reconnecting error.
Jan 15, 2021 10:49 AM UTC
Hi @Swapnil_More ,
I tried yesterday and today to upload the sample project /from the both posts/ but there is a still a Network error to download it.
So the quesiton is - if there is  some problem on upload. Are you able to download the Sample.zip when you click the linkn. If you face the same issue could you try to upload the project again. Thanks!
