I had a few requests to provide a highlight model option without using the Mapper widget. So updated the COETree to allow you to highlight model with a checkbox option on the COETree in the design view plus a button in UI to use Green red and yellow (default is green)
https://github.com/stevegw/COETree/releases/tag/V1.0.6
This is a code example post
