Hello Sir/Madam,
I created one Experience In which I bound data to label in preview it shows value but in IPAD it shows only "Label" text. (same thing happening with Gauge widget).
As well as when I am enable state definition to Gauge widget It shows only color (no value).
Could anyone explain me this behavior of Vuforia View?
Hi @Swapnil_More,
Could you please assign the Run time permissions for the es-public-access user to the properties, events and services of the entity whose data must be accessed by a public experience.
Hi @Swapnil_More,
Thanks for Help!!!
I have read this post and this can may be helpful for my problem also...
i am having issue that i have thing in thingworx and i update the property with service and then DataChange event i use in vuforia studio to do some task (with Datachange event i execute another service in vuforia studio). It works completely fine with my admin user but not with user of customer means composer user which has all rights i have assigned. would you please give you some insights..?
here is my post
