It is possible to play a video from youtube with just URL, without download it?
Thank you
Try the following solution ( link: https://developer.vuforia.com/forum/android/play-youtube-video ), quote: "In class VideoPlayBack there is a method onSingleTapConfirmed put this code inside it and enjoy youtube or any link".
Hi @RG_10041320 ,
the simples way could be to try to use thje video widget according to the help documentaion:
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetVideo.html
and usage of remote media:
boolean isSingleTapHandled = false;
// Do not react if the StartupScreen is being displayed
for (int i = 0; i < NUM_TARGETS; i++)
// Verify that the tap happened inside the target
if (mRenderer!= null && mRenderer.isTapOnScreenInsideTarget(i, e.getX(),
e.getY()))
if (i == 0)
Intent intra = new Intent(Intent.ACTION_VIEW);
intra.setData(Uri.parse("put ljnk here"));
startActivity(intra);
if (i == 1)
Intent intr = new Intent(Intent.ACTION_VIEW);
intr.setData(Uri.parse("put ljnk here"));
startActivity(intr);
if (i == 2)
Intent intr1 = new Intent(Intent.ACTION_VIEW);
intr1.setData(Uri.parse("https://yput ljnk here"));"));
startActivity(intr1);
//------ FUllScreen remove.... just uncomment the below code
// Check if it is playable on texture
/* if (mVideoPlayerHelper[i].isPlayableOnTexture())
// We can play only if the movie was paused, ready
// or stopped
if ((mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.PAUSED)
|| (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.READY)
|| (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.STOPPED)
|| (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.REACHED_END))
// Pause all other media
pauseAll(i);
// If it has reached the end then rewind
if ((mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.REACHED_END))
mSeekPosition[i] = 0;
mVideoPlayerHelper[i].play(mPlayFullscreenVideo,
mSeekPosition[i]);
mSeekPosition[i] = VideoPlayerHelper.CURRENT_POSITION;
} else if (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.PLAYING)
// If it is playing then we pause it
mVideoPlayerHelper[i].pause();
} else*/ if (mVideoPlayerHelper[i].isPlayableFullscreen())
// If it isn't playable on texture
// Either because it wasn't requested or because it
// isn't supported then request playback fullscreen.
mVideoPlayerHelper[i].play(true,
VideoPlayerHelper.CURRENT_POSITION);
isSingleTapHandled = true;
// Even though multiple videos can be loaded only one
// can be playing at any point in time. This break
// prevents that, say, overlapping videos trigger
// simultaneously playback.
break;
return isSingleTapHandled;
