I am creating an AR of big plant but i was unable to upload file on vuforia studio because it's is having file size more than 100mb and it's taking hours to upload and even it doesn't respond in the end.
Can any one help me for the same.
Thank you
For example by using a shrinkwrap or remove all 3D Models who are not visible.
Sometime, decrease the quality of the model is not visible in 3D application and is enougt to reduce size of the 3D Model.
Best regards,
Samuel
Best regards,
Samuel
We have extracted whole data from solidedge to creo in to step format and than we have converted in to pvz file. File size which i was trying to upload is 220mb after shrinkwrap.It's huge plant assembly which we need to augment.
While uploading it shows unhandled error pvz optimizer stopped working and log is also not generating.It get stuck at low quality leval.
Thank you
Please copy these error messages or the log file.
Without it, it will be very difficult to investigate and to help you.
The messages can help me to find more details in your knownledge database.
Thanks you in advance for your help.
Best regards,
Samuel
Please find here attached log file for your reference.
Thank you
Kindly reply asap because i need to submit it .
Thank you
In first log file provided, we can find this error :
[2019-06-11T13:20:06.896Z] error: [twx-studio:fileUtils] Error checking zip entries in file C:\Users\Admin\Documents\VuforiaStudio\Projects\CCM_12231\src\phone\resources\Uploaded\GA.pvz Invalid or unsupported zip format. No END header found [2019-06-11T13:20:16.952Z] debug: [twx-studio:resourceService] Processing file: GA.pvz C:\Users\Admin\Documents\VuforiaStudio\Projects\CCM_12231\src\phone\resources\Uploaded\GA.pvz [2019-06-11T13:20:16.957Z] debug: [twx-studio:sockets] EMIT file-status-change E12uJ_sTs0muSRuiAAAA [2019-06-11T13:20:16.959Z] debug: [twx-studio:cad-import-filters] executing: C:\Users\Admin\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\cad-import-filters\import_filters/bin/pvaroptimizer.exe -vc1,-p,C:\Users\Admin\AppData\Local\Temp\Studio-optimize2019511-13044-1h0i4av.hg4x,-o,GA,C:\Users\Admin\Documents\VuforiaStudio\Projects\CCM_12231\src\phone\resources\Uploaded\GA.pvz
So, it seems due to zip archive not uploaded completly in web interface in Vuforia Studio.
A very simple workaround, is to copy the pvz file directly in the right folder in Windows Explorer, in the folder :
%USERPROFILE%\Documents\VuforiaStudio\Projects\<ProjectName>\src\phone\resources\Uploaded
Be carreful, replace <ProjectName> by the Project name wanted
Reopen the Project in Chrome web browser.
Pvz file is listed under RESOURCES in Uploaded.
If needed, it is possible to run the command, to have same result as when switch on Run CAD Optimizer checkbox when importing 3D models in Vuforia Studio :
This workaround only works because we have already a pvz file.
Best regards,
Samuel
Thank you for reply.
I have tried to launch pvz optimiser but could not able to write a code as it runs that pvaroptimizer.exe and screen went it's doesn't wait for writing the code.
Thank you
Please follow these steps :
Best regards,
Samuel
In right click i haven't find any pop up for CAD shell.
Thank you
In the popup menu, it is this menu.
My screenshot is in French but it is similar in English or other supported language in Vuforia Studio.
Best regards,
Samuel
Where should i write a code kindly let me know for optimizing file size.
Thank you
Hello
please find here attached snapshot of error while running code.
Thank you
In your screenshot, the root folder is not this one :
%USERPROFILE%\AppData\Roaming\VuforiaStudio\studio-download.vuforia.io\node_modules\cad-import-filters\import_filters\bin
Please follow these steps in Command prompt:
Best regards,
Samuel
