Hi, all
I have a question.
how long can it scan the area target creation using IOS device?
when I try to scan to create area target using vuforia area target creator, I can scan the area for only five minutes.
and, Is there any method to increase the time to scan the area using Vuforia area target creator?
Quote: "The app supports a scanning time of 5 minutes. A countdown timer will automatically appear when there is 30 seconds remaining of the 5-minute mark. The countdown will appear in the upper right corner. If the 5 minutes are used up, the scan is automatically concluded, and you may choose to save or discard the scan" - "Vuforia Area Target Creator App": https://library.vuforia.com/creating-area-targets/vuforia-area-target-creator-app
Thnks for your answer.
I checked the time limit is 5 minutes.
You're welcome.
