Get programmatically Version History of document
AB_9905442
Hello ,
I want to display some data regarding Version History of document  (WINDCHILL 11)
version , file name , state , comments ,modified by and last modified
HelesicPetr
(To:AB_9905442)
Hi @AB_9905442
btw the VersionControlHelper contains an other method that returns all iterations. allIterationsFrom
try
	WTDocument document = getDocumentByNumber("0000000142");
	QueryResult allVersions = VersionControlHelper.service.allIterationsFrom(document);
	while (allVersions.hasMoreElements())
		Object obj = allVersions.nextElement();
		if (obj instanceof RevisionControlled)
			RevisionControlled iterationObject = (RevisionControlled) obj;
			System.out.printf("numer> %s - name> %s - version> %s %n", iterationObject.getDisplayIdentifier(), iterationObject.getName(), iterationObject.getIterationDisplayIdentifier());
} catch (QueryException e)
	e.printStackTrace();
} catch (WTException e)
PetrH
14 REPLIES 14
HelesicPetr
(To:AB_9905442)
Hi @AB_9905442
You can try this method that returns all versions so the history is based on all version.
Information can be collected from each object that is returned in a query...
QueryResult allVersions = VersionControlHelper.service.allVersionsOf(document);
then you can use following methods to get some info..
iterationObject.getCreateTimestamp();
iterationObject.getCreator();
iterationObject.getModifier();
iterationObject.getVersionDisplayIdentifier();
 the document variable can be Mater object or any Versioned one.
example
WTDocument or WTDocumentMaster
EPMDocument or EPMDocumentMaster
PetrH
AB_9905442
(To:HelesicPetr)
Hello ,
Thank you for the methode , but it display only 2 iteration
AB_9905442
(To:AB_9905442)
 this is our example
Have you used they Query Builder before? You could create a query to display this information
Some info to help you get started: https://www.ptc.com/en/support/wnc-reporting-landing/wnc-reporting-landing-main/querybuilder-intro/qb-intro?overlay=BDDBFF62-6C2F-436C-A38B-BF1BDD6B3F23&source=search
rleir
(To:AB_9905442)
Programmatically as in an external program making REST OData API calls? Or an external program making REST calls for QB data? Or a program integrated in the WC server?
AB_9905442
(To:rleir)
Hello @rleir ,
A methode like  the first comment
HelesicPetr
(To:AB_9905442)
Hi @AB_9905442
And is it wrong? why? you didn't provide real data if there are just versions A.1 and B.1 the result is correct.
PetrH
AB_9905442
(To:HelesicPetr)
this is our example
HelesicPetr
(To:AB_9905442)
Hi @AB_9905442
Obviously the method returns just latest versions of all revisions.
So you can use another method as a query definition
WTArrayList retValue = new WTArrayList();
QuerySpec queryspec;
try
if (revObj instanceof WTDocument)
	queryspec = new QuerySpec();
	int idWTDocObject = queryspec.appendClassList(WTDocument.class, true);
	//podmínka vyhledávání
	CompositeWhereExpression andCondition = new CompositeWhereExpression(LogicalOperator.AND);
	andCondition.append(new SearchCondition(WTDocument.class, WTDocument.NUMBER, SearchCondition.LIKE, ((WTDocument) revObj).getNumber()), new int[]{idWTDocObject});
	queryspec.appendWhere(andCondition, new int[]{idWTDocObject, idWTDocObject});
	queryspec.appendOrderBy(new OrderBy(new ClassAttribute(WTDocument.class, WTDocument.MODIFY_TIMESTAMP), false), new int[]{0});
	QueryResult qResult= PersistenceHelper.manager.find((StatementSpec) queryspec);
	retValue.addAll(qResult);
PetrH
AB_9905442
(To:HelesicPetr)
@HelesicPetr  Thank you for the methode , its display all the documents
from this  can  i get  version , file name , state , comments ,modified by and last modified  as the picture ?
HelesicPetr
(To:AB_9905442)
@AB_9905442
Yes, go one by one result document version and get all the information what you need.
PetrH
HelesicPetr
(To:AB_9905442)
Hi @AB_9905442
try
PetrH
AB_9905442
(To:AB_9905442)
I implemented this methode  it's ok but the first iteration not exist ( A1)
 WTDocument refreshedDoc = (WTDocument) PersistenceHelper.manager.refresh(document);
	        // Get the version history
	        QueryResult versionHistory = VersionControlHelper.service.allIterationsOf(refreshedDoc.getMaster());
	        // Display the version history information
	        int i=1;
	        while (versionHistory.hasMoreElements()) {
	        	String iteration="";
	        	String version="";
	        	String fileName="";
	        	String state="";
	        	String coments="";
	        	String modifyBy="";
	        	String lastModified="";
	            Object versioned = versionHistory.nextElement();
	            if (versioned instanceof Iterated) {
	                Iterated iterated = (Iterated) versioned;
	                iteration = getVersion(iterated);
	                IterationInfo iterationInfo = iterated.getIterationInfo();
	                coments=iterationInfo.getNote();
	                modifyBy= iterationInfo.getModifier().getFullName();
	               // taskLogger.debug("iteration: " + iteration);
	               // taskLogger.debug("getModifierName: " + iterated.getModifierName());
	                modifyBy=iterated.getModifierName();
	                lastModified=iterated.getCreatorName();
	                if (iterated instanceof LifeCycleManaged) {
	                    LifeCycleManaged lifeCycleManaged = (LifeCycleManaged) iterated;
	                    state= lifeCycleManaged.getLifeCycleState().toString();
	                    //taskLogger.debug("state: " + state);
	                if (iterated instanceof WTDocument) {
	                    WTDocument doc = (WTDocument) iterated;
	                    //taskLogger.debug("doc: " + doc.getNumber());
	                    ContentHolder holder= ContentHelper.service.getContents(doc);
	                    ContentItem  ci = ContentHelper.getPrimary((FormatContentHolder) holder);
	                    ApplicationData  ad = (ApplicationData) ci;
	                    fileName = ad.getFileName();
	                    //taskLogger.debug(doc.getIterationInfo().getIdentifier().getValue());
	                   // taskLogger.debug(doc.getVersionInfo().getIdentifier().getValue());
	                    version=doc.getVersionInfo().getIdentifier().getValue();
	            taskLogger.debug("----------------------"+i+"---------------------------------");
	            taskLogger.debug(version+iteration+"---"+fileName+"---"+state+"---"+coments+"---"+modifyBy+"---"+lastModified);
	            i++;
how can i display also A1 iteration
HelesicPetr
(To:AB_9905442)
@AB_9905442
I've already answered.
PetrH
