I want to create a new part in Windchil.
But the Icon is not available in the Ribbon.
Also by selecting: Actions > New I am not able to select the Part Icon.
Any ideas?
regards,
Bert
The new licensing model moved this capability to the EBOM Management License.
What version of Windchill are you using?
From 11.1, the actions you can perform depend on the license profiles you have been assigned to
Under Site --> Profiles you can find the existing profiles
For each one the actions available in the various contexts (Libraries, Products, Projects, etc...) are indicated.
See below image
Hi @bbusschers
The action availability also depends on what ACL rules are granted to you by roles in a context team.
License group can change a visibility of the new WTP action button as @Marco_Tosin mentioned .
You need to check it with your system administrator
PetrH
Yeah, I agree with the other commenters. This is most likely either an access issue within that Product/Library, or a licensing issue. It's possible it could also be a custom profile. Any of those would be a question for your system admin to address.
