How do I achieve simulated results of MTBF and MTTR in the RBD? Windchill displays an error.
NC_11295418
3-Visitor
Hi all, this is my first experience with the software. I am currently learning the functions and utilities of the Windchill RBD. At the calculation page, I have been enabled Monte Carlo Simulation method. I am unable to achieve the simulated results. The results page display a message. I am able to obtain the failure rate for this example. It just unable to obtain the MTBF and MTTR of the overall system.
"All availabilities are operational availabilities. *Cannot be operated because the system will enter a failed state where it cannot be repaired"
I read some of the guides including Getting Started Guide. I was still unable to comprehend the error that I encountered. Appreciate the guidance and cheers.
https://community.ptc.com/t5/Windchill/Windchill-Fault-Tree-Analysis-questions/m-p/383375#M44847
Hi @NC_11295418,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Thank you for your participation!
Catalina
PTC Community Moderator
